| | | Forums66 Topics128,032 Posts1,055,521 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 49 | The transmission in my 55 2nd series has been changed to a later model. The trans has the following numbers cast into the side:
GM23 8825647 F82
The following number is stamped on a machined spot above these on the right side of the transmission:
12w419838
Can anyone tell me from these numbers what transmission this is? Since it is not the original transmission, is it the same or a different length as the stock? Length measures 21.5 inches from front to back. How will this effect a change to a T5? Will the T5 still be longer than 21.5? I am trying to figure out if I will need a shorter driveshaft.
Thanks, Hugh
