| | | Forums66 Topics128,094 Posts1,056,489 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Safety issues aside, the original configuration of the hand throttle does allow for gas pedal override.
The way it mounts is that the center of the throttle cable replaces the cotter pin that holds the accelerator linkage rod into the throttle lever on the carb. When you pull the hand throttle, it tugs the throttle open, but the rod is still free to slide on the cable end so if you floor the gas it still moves.
Another option is to run a short length of chain between the end of the cable and the throttle linkage to accomplish the same thing.
