| | | Forums66 Topics128,087 Posts1,056,112 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | The inductive (as sold by Snap-on; I'm sure that there are less-expensive ones available) or Hall-effect ammeters are used to measure the current drawn by the starter. As was mentioned, the current drawn with a 12-volt starter and battery should not be much above 200 amps. Did you say how fast it cranks with the spark plugs removed? Hoyt
