| | | Forums66 Topics128,132 Posts1,056,379 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | 6V and 12V starters have a different pitch on the gear teeth, and the flywheel ring gear has a different number of teeth, IIRC. The ring gear and starter pinion gear has to match, or both get damaged. It might be possible to fit a different ring gear to the flywheel, but it's considerably easier to just swap to the correct flywheel. Jerry
Entire Thread
Flywheel, Starter, and 12 volts
| GMCdp | 08/21/2008 6:11 PM |
Re: Flywheel, Starter, and 12 volts
| Hotrod Lincoln | 08/21/2008 6:17 PM |
| GMCdp | 08/21/2008 6:42 PM |
| crenwelge | 08/21/2008 6:48 PM |
| Curt B. | 08/21/2008 7:10 PM |
| crenwelge | 08/22/2008 1:25 AM |
| jdl | 08/22/2008 1:29 AM |
| crenwelge | 08/22/2008 2:45 AM |
| GMCdp | 08/22/2008 2:54 PM |
| crenwelge | 08/22/2008 4:27 PM | |
