0 members (),
35
3
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | When trying to remove a rear axle, I the bolt that holds the differential pin that must be removed to gain acces to the retaining rings holding the axle in place is broken(the bolt) the bolt came out but the end of it that holds the pin in is broken and stuck. Any good ideas ? I plan ondrilling it out I guess. | | |
