You didn't say weather you checked the push rod free play like TC sugested. Ithink it is not letting the piston come back all the way. There should be a small amount of free play in the pedal before it pushes on the cyl. Ther is an adjustment on the rod. Some use an eccentric bolt. You loosen the nut & turn the bolt to adjust it.
