| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44203 03/03/2004 7:43 AM | Joined: Oct 2003 Posts: 15 Member | | Member Joined: Oct 2003 Posts: 15 | The cable on the drivers side hand brake is stuck on. The truck wont move at all , I tried to rock it , and nothing. I was looking at the cable while a friend pulled the lever back and forth..It moved only up to the coupler then stopped. I pulled the tire to look in the drum, but do I need to remove all the boltd in the middle of the hub to get the drum off..[the truck is a 3/4 ton]
thanks | | |
