8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44138 11/26/2002 8:25 PM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Small Block Chevy Valve Adjustment Order 0 deg TDC, both number one valves shut. Adjust the #1 exhaust valve Adjust the #1 intake valve Adjust the #3 exhaust valve Adjust the #5 intake valve Adjust the #7 intake valve Adjust the #2 intake valve Adjust the #4 exhaust valve Adjust the #8 exhaust valve Now rotate the engine 360 degrees. The mark on the balancer should be back at the TDC mark. Keep in mind that this is not the TDC where #1 would be firing! It's where #6 would fire. Adjust the #3 intake valve Adjust the #5 exhaust valve Adjust the #7 exhaust valve Adjust the #2 exhaust valve Adjust the #4 intake valve Adjust the #6 exhaust valve Adjust the #6 intake valve Adjust the #8 intake valve This should be what you need. | | |
