Before I loose my %$#@%^&ing mind. Can someone please tell me through these numbers what engine this is. The numbers are from off the block on the drivers side back at the firewall area. I have 5 people INCLUDING Canadian Tire saying 5 things. I repeat to them the engine is probably NOT the original engine. Here are the numbers 3958188 Thanx ! I should have come here in the first place where the real pros are. Cheerz !
