Is it new enough for a computer if so some you can turn the key on and off 3 times and it will blink a code to tell you the problem. But you need a book to tell you how to get code and what code means. good luck
Bill 1951 3/4 ton 5 window pick up 1955 GMC 1/2 ton longbed automatic
