| | | Forums66 Topics128,081 Posts1,056,321 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43055 05/31/2002 7:06 AM | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | Clean everything back off and really get it dry. Try using brake clean to really clean it. The on the ends us a weatherstrip glue and let them set up. They should be dry and in place before you try to install pan. Some of the Permatex glues are all so good to use. Just use one that sets up and drys in a short time for the end pieces. For the sides, silicon or you choice of glues. Joe | | |
