2 members (51sub, Possum),
113
Mod | | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Free to a good home. Another way to go about the disc brakes is to use a 41-54 front axle on your 37. It is a bolt on change that is actually an upgrade in itself due to the larger diameter kingpins. It does sound like you have things worked out with your 37.
On my 1940 GMC I will be changing out the front axle to the later one and using the CPP 12 inch 6 lug disc brakes. I am curious to see what you came up with for a master cylinder mount.
John | | |
