| | | Forums66 Topics128,265 Posts1,058,363 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | The Truck is a 37 GMC 1/2 ton. I have those step sleeve in my kit also, the step were the bearing goes mics at 1.380 the inner bearing for the rotors they told me to use is 1.250. the rotor that fits the backing plate will work with 11" rotors but not 11 1/2"althought the 11 1/2" rotors have the right sized inner bearing but the wrong size outer bearing.
Bigbad I'll let you know by this week end what would the $ be
1938 Gmc 1/2 ton
