Denny,
You are right, it will only work for the push button handles. My 1953 restoration packet states you could also have a lock on the drivers side at a extra cost. I got a handle from a donor truck, removed the clyinder and took it to a locksmith and had the tumblers changed to fit the orginial truck key. I then installed it in the driver's side handle.
