| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | In reply to DLEE's question........... No the air/fuel adjustment is only for fine tuning and will not effect the motor enough to soot up plugs. Dirty plugs will aways come from severe over fuelling. High float, sticking needle/seat, too high delivery pressure, wrong jetting in carby etc. But it sounds like you must have a problem with your fuel lines/filter/tank etc. after reading your post Yippee ti iy ay. If you bypassed all this and the engine is happy....at least now you know what you need to fix and replace. As I said at the start of this saga......"Start with the simple things first and use the process of elimination until the problem is found". "The cause will almost always be the smallest least expensive thing, but can cause the biggest headaches!" all the best Doc Bob. | | | |
Entire Thread
ignition problem, will start, run, then dies out both at idle & on the road
| D.Lee | 05/27/2008 5:30 AM |
Re: ignition problem, will start, run, then dies out both at idle & on the road
| doc bob | 05/27/2008 5:56 AM |
| D.Lee | 05/27/2008 6:45 AM |
| beltfed | 05/27/2008 2:33 PM |
| atomarc | 05/27/2008 3:10 PM |
| D.Lee | 05/27/2008 6:37 PM |
| jdl | 05/27/2008 8:51 PM |
| 41Chevy | 05/27/2008 11:39 PM |
| D.Lee | 05/28/2008 4:18 AM |
| doc bob | 05/28/2008 2:33 PM |
| JiMerit Boltr#43 | 05/28/2008 4:24 PM |
| D.Lee | 05/28/2008 6:19 PM |
| jdl | 05/28/2008 6:23 PM |
| Birge Robinson | 05/28/2008 10:23 PM |
| doc bob | 05/29/2008 2:34 PM |
| doc bob | 05/29/2008 2:45 PM |
| jdl | 05/29/2008 3:41 PM |
| atomarc | 05/29/2008 3:59 PM |
| D.Lee | 05/30/2008 5:21 AM |
| doc bob | 05/30/2008 12:05 PM |
| doc bob | 05/30/2008 12:12 PM |
| D.Lee | 05/31/2008 8:22 PM |
| Birge Robinson | 05/29/2008 3:48 PM |
| D.Lee | 05/28/2008 6:16 PM |
| D.Lee | 05/28/2008 4:14 AM |
| AD_Pickup | 06/01/2008 12:39 AM |
| atomarc | 06/01/2008 3:10 AM |
| jdl | 06/01/2008 3:55 AM |
| doc bob | 06/06/2008 4:59 AM | |
