Does RR, LR, RF, LF bleeding hold true on every vehicle? On my '50 the longest line from the master is the driver's rear because the line to the rear runs down the passenger side. While the right rear cylinder is physically farther away, it is actually on a shorter line than the left/driver's rear. Same is true upfront with the stock lines because the LF line comes from the passenger side again. Wouldn't you bleed it LR, RR, LF, RF?
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
