As far as I know those mounts are '53-'54 only. I'm sure you could make up something to go between the '54 frame and '60 engine though. Or maybe someone already makes these? I would try calling National Chevy in St. Paul, MN. at (651)778-9522. All they deal in is '53-'54 Chev. stuff and they would know if mounts are available to adapt the newer 235 block into the '53-'54 frame.
