8 members (Bill Hanlon, 52Carl, Danielbolt, Hotrod Lincoln, NJC, Stovebolt48, Gdads51, 1 invisible),
46
3
Mod | | | Forums66 Topics128,180 Posts1,057,163 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | Seems to be a common occurance in the ol' Stovebolt world at the moment !Have a buzz through some of the forums and you will no doubt find a few of these questions at the moment. A quick guess from this side of the world would be to check your float level and the needle and seat in the carbie. A classic problem is a sticking needle and seat which will let the engine start, run , idle etc. and then fuel up the engine, foul the plugs and cause it to stall after a short time. Your bowl might appear to have "plenty of fuel" in it, but is it set at the correct height? A float level too low will have the same result. I'm leaning towards this as you say all the ignition system will start and run the engine.........so obviously no problem there! Give all that a check and see what you find...Good Luck.......Doc Bob. | | | |
Entire Thread
ignition problem, will start, run, then dies out both at idle & on the road
| D.Lee | 05/27/2008 5:30 AM |
Re: ignition problem, will start, run, then dies out both at idle & on the road
| doc bob | 05/27/2008 5:56 AM |
| D.Lee | 05/27/2008 6:45 AM |
| beltfed | 05/27/2008 2:33 PM |
| atomarc | 05/27/2008 3:10 PM |
| D.Lee | 05/27/2008 6:37 PM |
| jdl | 05/27/2008 8:51 PM |
| 41Chevy | 05/27/2008 11:39 PM |
| D.Lee | 05/28/2008 4:18 AM |
| doc bob | 05/28/2008 2:33 PM |
| JiMerit Boltr#43 | 05/28/2008 4:24 PM |
| D.Lee | 05/28/2008 6:19 PM |
| jdl | 05/28/2008 6:23 PM |
| Birge Robinson | 05/28/2008 10:23 PM |
| doc bob | 05/29/2008 2:34 PM |
| doc bob | 05/29/2008 2:45 PM |
| jdl | 05/29/2008 3:41 PM |
| atomarc | 05/29/2008 3:59 PM |
| D.Lee | 05/30/2008 5:21 AM |
| doc bob | 05/30/2008 12:05 PM |
| doc bob | 05/30/2008 12:12 PM |
| D.Lee | 05/31/2008 8:22 PM |
| Birge Robinson | 05/29/2008 3:48 PM |
| D.Lee | 05/28/2008 6:16 PM |
| D.Lee | 05/28/2008 4:14 AM |
| AD_Pickup | 06/01/2008 12:39 AM |
| atomarc | 06/01/2008 3:10 AM |
| jdl | 06/01/2008 3:55 AM |
| doc bob | 06/06/2008 4:59 AM | |
