Ed and Hoyt,thanks for the information.I went to lmc today and purchased the right oil pump for my engine.My pump is listed as the 1954-1955 1st series pump and yes the 235 is the same pump.
sealed power # 224-4142 has m-29 stamped on pump shaft housing.
melling part # m-29
Here are a couple of pics of the new pump beside the original.
1954-1955 1st oil pump 1954-1955 1st m-29 oil pump I do have a question about the pickup tube>I will start a new post on it.
Thank you for your help,Tim
