9 members (frogfarmer, J Lucas, Gdads51, carbking, Charles in CA, Wally / Montana, Nick in Manitou, sron48, 1 invisible),
88
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41631 03/12/2005 6:18 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 4L60E is controlled by electronics, no way that I know of to convert them since the valves are operated by solenoids. TCI makes a computer to run it for you, but it isn't cheap. http://tciauto.com/electronics/index.htm Summit sells them. This is from Novak Earlier engines can be joined to the 4L60-E by use of a GM Controller, #12497316. Carbureted engines will require a Throttle Postion Sensor.
Fred 52 3600 69 C-10
