| | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The hydro will not give you any more top end speed, than any other stock trans for your truck. Final gear ratio is one to one. The rear end will have to be upgraded with taller gears or changed to a later model rear end with taller gears. 3.33 to one gears are available for the 55.1 rear axle which will net you more top end than the stock 3.90 gears. | | |
