I installed 2 fiero seats in my '41. I welded 2 brick window lintels together into a Z and used that for the back mount. It gets the height up so the filler neck only comes in a couple incnes but does not interfere with the seat mount. Raising the rear of the seat makes a much more comfortable seating position. I added a piece of 16 ga steel to cover the tank. I welded the seat frames to angle iron. I added a piece of punched angle to the inside of the front edge of the tank surround and fastened it with "stovebolts". I then welded nuts on the bottom sides of the punched angle and the "Z" back mount and fastened the angle iron to those nuts.
Harold Wilson
41 Chevy 3/4 Ton
