0 members (),
117
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | If the shoes are frozen to the drums and will not release, try cutting the heads off the "nails" that secure the shoes to the backing plates. Take a small angle grinder with a cutoff wheel, and grind away the head of the nail. The shoe and drum assembly can then be pried away from the backing plate far enough to get a pry bar inside the drum and dislodge the wheel cylinder pins. If things are that bad, you'll probably end up replacing everything inside the drums anyhow. Jerry
