3 members (baldeagle, Wayne67vert, 1 invisible),
91
7
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#40440 03/04/2005 8:18 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Its best to put the filter on the outlet side of the pump, mounted vertically before you get up to the valve cover crossover. That way if the filter springs a leak the hot gas doesn't drip onto the manifold, it just hits the lower block which is much cooler.
Mechanical pumps don't suck very well so only put a screen filter at most in between it and the tank.
