1 members (52Carl),
105
2
Mod | | | Forums66 Topics128,062 Posts1,055,845 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39706 05/03/2002 6:29 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | That should be a TH700R4.The early ones were not that strong.Look for a later one or have someone update that one with a rebuild and use stronger parts.If you want to handle horsepower, ust the TH400.There is a place that sells performance built TH400`s and TH700R4 trannys capable of handling a LOT of torque.The overdrive is nice but they are expensive.
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
