1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39705 05/03/2002 4:17 AM | Joined: Mar 2002 Posts: 10 Member | | Member Joined: Mar 2002 Posts: 10 | I Got a transmission from a machanic and it is out of a 1991 chev van The van had a 350 in it. Well the motor blew and the van was scraped.The tranny is supposed to be a TH 700 it has 1-2-3-OD.I am hoping to use this in my 54 P/U Would it be stronger than a 350 or a 400 tranny.The motor I am useing is a 400 hp 350.I dont know alot about trannys so any help would be great. Thank :confused: | | |
#39706 05/03/2002 6:29 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | That should be a TH700R4.The early ones were not that strong.Look for a later one or have someone update that one with a rebuild and use stronger parts.If you want to handle horsepower, ust the TH400.There is a place that sells performance built TH400`s and TH700R4 trannys capable of handling a LOT of torque.The overdrive is nice but they are expensive.
