| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39501 06/16/2003 7:13 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I-6's on surface by the distributor. ON V-8's it is stamped on the part of block that sticks out past the pass side (right) head. I don't know on V-6's like yours, but that may be good choice. May have some letters and then numbers, which are a date code. Letters tell year, vehicle it's in, and trans usually used or carb maybe. You'll need a chart for the codes from somebody or dealer.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
