0 members (),
40
2
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37649 06/18/2004 2:42 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I'll look for a photo but maybe I can explain how I did mine.
The vertical throttle linkage from the block to the carb has a right angle bend at the top. The short piece of the bend goes through the carb throttle lever. It has a hole at the end and was held in place with cotter pin when I got my truck. I put my throttle cable through that hole and put a cable clamp on the end of the cable. You also have to clamp the outer part of the throttle cable vertically pointing down.
Yep, a picture would be worth all those words! 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
