| | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#3754 06/27/2002 12:49 AM | Joined: Jun 2002 Posts: 50 Member | | Member Joined: Jun 2002 Posts: 50 | Well I looked again and there is no cap to hold the u-joint on. The trannie end had a 3/4 round end and the u-joint bushing rides in it. They do have C clips on the inside that I took off and thought I could slide the bushing out, then slide it back through the opening, were the end cap should be, but there is not enough room to slide the bushing out without hitting the housing. I know it can't be as hard as I'm making it. Any help would be nice. I'll try and post a picture of it if I can. Thanks
If it ain't broke I ain't worked on it.
