1 members (2-Ton),
87
Mod | | | Forums66 Topics128,187 Posts1,057,316 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I don't know how wide the rear end can be for a 36 but I would say you could probably use a 55-57 car rear end but not a 55-59 truck. An S-10 is also a good possibility. Maybe others have an opinion on this. There are lots of transmissions available from 55 up including a couple of overdrives. The full oil pressure 235 is a good choice and will run forever. I know there are ring and pinion gears available through assorted aftermarket suppliers for AD & TF trucks but have no knowledge on the earlier ones. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
