| | | Forums66 Topics128,186 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The "torque tube overdrives" were somewhat common many years ago but for the most part they are unobtainum. There is an article on them in Tom Brownell's book "How to restore your Chevrolet pickup" which was printed some time back. A B/W or other OD assy was incorporated into the torque tube which required extensive machining, welding, and skills. I have seen them on Model A's and a friend had a 46 Ford ragtop that had one installed. You would be better off converting to an open driveline where you would have more options. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
