| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36865 07/26/2002 6:32 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Wellit is around 12 to 20 bucks and you can basically rebuild the carb on the fender or the tailgate in an hour if you are comfortable with (easy) carbs.It may need to have a good fuel filter put on it as it has been sitting for a while and rust/sediment will most likely be a problem. You can possibly make it run with the carb that is there. . I would be sure to look /test the brakes as they are prone to loosing fluid if sitting a long time. Does this truck have the original 9-foot bed on it?
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
