gidday again stovies after a close inspection and detection the vibration maybe coming from the clutch plate it looks a little thin on one side so maybe coming from there? shes starting to slip in top gear and 3rd theres no oil on the plate just abit thin one side also can i change the torque tube and diff over to regular driveshaft and diff cause the one now shes abit rough .what type do yous suggest thanks pete the plumber
