1 members (baldeagle),
69
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36687 04/01/2002 4:46 AM | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | gidday again stovies after a close inspection and detection the vibration maybe coming from the clutch plate it looks a little thin on one side so maybe coming from there? shes starting to slip in top gear and 3rd theres no oil on the plate just abit thin one side also can i change the torque tube and diff over to regular driveshaft and diff cause the one now shes abit rough .what type do yous suggest thanks pete the plumber
p j a
#36688 04/01/2002 5:36 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Pete, need more description in your posts on what you are working on and pertaining to. It's hard to remember all of a single guys posts here. That said, what ARE you working on? If you have a tork tube, the trans will need to be changed to open line type too and diff rear. If you go to the "archives" and search or the "tech" articles on the main page, lots has been said on these two items. Finding a 55-1 first series will get you an open rear and trans that will just bolt in. Kinda rare to find, specially in New Z I would think. This is assuming you have an AD 48-54. What DO you have and what size? 3/4-tons or one-tons with 4spds are usually all open drive too, even back in the older ones.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#36689 04/01/2002 6:07 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | It appears from his profile that his truck is a 46.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#36690 04/02/2002 10:45 AM | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | gl and oly shes a 1946 1/2 ton wellside crash 4 speed 235 blue flame torque tube diff so ill look up archives thanks boys pete
p j a
