OK, Kip. I'm not saying I'm right, but it just makes sense that there should be a bumper there. What if you come up with a piece of something that you can size to act as a "dummy" bumper for the brake pedal? By doing that, maybe you can get the right thing going on.
On the other hand, with the master cylinder on the frame, there is a long rod, if memory serves me correctly, that it seems can be adjusted to length, as you said. Let's look at that again! As you can tell, I'm kind of stalling here until someone else comes in and tells us both exactly what needs to be done.
Just trying to help!
Joe :crazy:
