| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Are the brake and clutch pedals on a ’41 supposed to be the same height?? My clutch pedal is about 3 inches shorter (below) the brake pedal. The clutch pedal is sitting right up against the rubber stop on the front side of the toe board so it is as high as it is going to get. The brake pedal is sitting against the toe board as there is no stop or place to install a stop that would make it lower. Both are properly connected at the pivot and there are new bushings there. Neither of the pedals show any sign of welding so I’m thinking they have not been modified, it just seems strange that they are so different in height. Maybe at some time over the years someone with one short leg installed different pedals. | | |
