| | | Forums66 Topics128,165 Posts1,056,989 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35457 08/09/2004 5:00 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Tried the water pump lube and seal rejuventor. Week later forced to change the pump. It did nothing to help. Bite the bullet and change the pump because some of these "miracle" fixes are just snake oil! Are you certain it is the pump. Try running the motor without the belt and then you can hear if it is the pump or something else. | | |
