1) Has anyone heard any pro's or con's on using synthetic wheel bearing grease on the old 1950's front "barrel type" wheel bearings?
2) Is the White Lithium grease a prefered lube for drum brake mechanisms, or is there something better that won't effect the brake shoes?
