I am buttoning up the 270 and need to know what is the proper way to check the clearance on the rocker arms. I understand that the clearance should be .12 and .20 but how/when do I measure this? I have to assume that the measure should be taken when the valves are closed, however I want to know exactly what the correct process is so that I do not screw anything up.
Thanks for your help.
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
