| | | Forums66 Topics128,088 Posts1,056,348 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34901 08/11/2003 5:01 PM | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | If it was mine, I would want to here it run if I had plenty of time. If you are really rushing around, let it set. Pull the plugs and spray the cylinders down with a rust inhibitor and reinstall the plugs then when you get back to it fire it up. Joe | | |
