| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | NO DON’T try applying power to it! In a radio that is that old it is almost guaranteed that the capacitors are going to be bad and you take a pretty good chance that you are going to damage components that are irreplaceable. If you burn up the power transformer you might as well junk the radios because you will never find another one and it would cost over $100 to have it rewound even if you could find someone to do it. If you have no experience with working on old radios I would suggest contacting your local radio club and asking for advise. Radios of the type you have described are rather rare an could be quite valuable if complete. If your intention is not period restoration for your truck then I would just conceder selling it and purchasing one of the newer radios. Denny Graham Sandwich, IL
Denny G Sandwich, IL
