7 members (FishinToms53, Hotrod Lincoln, Rich'sToys, Stovebolt48, 50shep, Millenimech, mason86),
75
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33437 12/04/2004 2:03 AM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I thought I had found a solution by purchasing some aftermarket wheels. I've been running into a lot of issues.
The wheels fit great with a 1/4" spacer but I would have to change the front wheel studs. Now that I've found the correct studs, the hubcap clips I ordered do not fit my 3/4 ton.
I'm to the point that I'm about ready to give up. The only option is to have Stockton Wheel take my hubs and weld them to a modern rim. The problem is they want $105 plus shipping for each rim. Seems like a lot.
Email me if you need more help. However, there doesn't appear to be a reasonable solution. Believe me...I've researched it pretty hard. | | |
