| | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33325 03/26/2004 9:52 AM | Joined: Feb 2004 Posts: 29,953 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,953 | Pull all the spark plugs, and turn the fan. (Clockwise from the front!) With a tight fan belt, the engine should turn. Another method is to put the truck in high gear, and gently roll it forward until #1 rolls up to TDC. BTW, the timing mark comes up twice, once at the top of the compression stroke, and again at TDC on exhaust. One of our guys here spent a couple of weeks figuring that one out! Be sure both valves are closed on #1 when you line up the timing mark! Jerry
