| | | Forums66 Topics128,258 Posts1,058,333 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Goop around the stick will not work at least i have found in my expierience . Only way i have ever found to remedy the problem is to remove the dipstick and replace the O-Ring seal add a generous amount of vasoline to the seal and take your time reinstaling it to make sure you dont tear it. On my project the tube was beat up and dented from PO , probabaly installin the motor an trans , any how i purchsed a replacement stick from Summitt it is a Hughes performance it was a bit pricey i thought but there Seal desighn on the end of tube is pretty much BULLETPROOF ! Just tossin out an Idea Tim | | |
