| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32453 05/06/2005 3:59 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I found an old rod with a flat end in dad's junk (er I mean stuff) that I chucked in the drill. Whatever you find that will fit the drill and engauge the pump will work fine. Like Brian says, you will know when the pump gets primed. I also had dad check the oil guage while I was pumping.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
