4 members (Phak1, carbking, 2 invisible),
115
3
Mod | | | Forums66 Topics128,260 Posts1,058,322 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31456 11/04/2002 8:33 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think what I will do is use the 261 stat housing if I can get it to fit ok and use the 216 flywheel and clutch until I fell like converting to 12 volts. Is it possible to have the 216 flywheel machined to fit an 11" clutch, or is there a high friction clutch available for the 216? I am using an SM420 with the stock gears so it shouldn't be too hard on the clutch I guess.
