1 members (Shardean),
113
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31366 02/08/2005 8:14 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Do you have the wood/phenolic spacer between the carb and manifold? It's purpose is to keep the carb from getting heat-soaked and boiling over. If you don't have it then you need to check your float level or replace your needle & seat.
