| | | Forums66 Topics128,163 Posts1,056,962 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30941 06/21/2004 2:39 PM | Joined: Feb 2004 Posts: 29,860 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,860 | The T5 will probably work OK, as long as you don't hotrod it. A Saginaw 4-speed would be stronger, but you'd need to use a slightly higher-ratio rear end to get the RPM into a better range IMHO. Jerry
