1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30934 02/11/2003 9:35 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You'll still need the heat riser. As for choke, the last I knew Tom had water heat, he used to have electric. Either one will work. Linkage will be your biggest problem. What did Tom tell you about that?
Fred 52 3600 69 C-10
