2 members (2-Ton, farmallb), 67 guests, and 4 robots.
Topics128,021
Posts1,055,352
Members48,420
#30933 02/11/2003 8:48 PM
Back again looking for advice from the experts. I thinking of putting a Holley Weber 2bbl on my 235. I'm looking at the ones on langdons web site, I can get the adaptor and carb resonalble. My question is what has to change? Do I still need to use heat to the bottom of the intake with this setup? What about vacuum to the vacuum advance and what is the choke setup, manual or vacuum?
Bruce
If it ain't broke I ain't worked on it.
#30934 02/11/2003 9:35 PM
You'll still need the heat riser. As for choke, the last I knew Tom had water heat, he used to have electric. Either one will work. Linkage will be your biggest problem. What did Tom tell you about that?
Fred
52 3600
69 C-10
